Click Pop up format different from Search bar result Pop up format for the same asset in ArcGIS online
1583
09-27-2022 12:04 PM
Labels (3)
AbiodunKaka1
I am encountering a problem in my webapp. Whenever I use the search bar to search for an asset in the web app, the pop-up format I get is different from the the pop up whenever I click on the same asset in the webapp. How best can I harmonize this pop up to have the same format with my configured click pop up?
jcarlson
Is your search bar widget configured to look at the layer in the map, or the feature service layer directly? If the search widget it looking at the layer directly, it will pull the popup configuration from the layer's default.
If it doesn't conflict with other maps / apps out there, consider going to that layer's Visualization settings and changing the default popup to match what is in the map layer. Then the popup should look the same regardless.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
AbiodunKaka1
Thanks your help. It works.
MichaelKohler
The accepted solution didn't work for me. I tried configuring the popup on the layer itself and not the layer in the web map. It still showed all the fields.
What I ended up doing was to create a custom attribute display and it worked. Note, this was for the classic web map and not the new one.
