Map creation failed on ArcGIS FieldMap Designer
465
02-10-2026 12:58 AM
Ud
I'm getting massage "Map creation failed" while try to create a New map on ArcGIS Field Map Designer
Tags (1)
Katie_Clark
MVP Regular Contributor
Some additional information would be helpful for troubleshooting this.
  • Has this workflow worked for you in the past, or has it always resulted in an error?
  • What settings are you using when creating a new map? (i.e. start with new layers, start with map template, etc.)
  • Are there any other errors that show up in the developer console or elsewhere on the page?
  • What is your user type and role in your AGOL account?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Ud
Hi Katie,
Thank you so much for the follow-up! I managed to troubleshoot the process, and it is working correctly now.
Katie_Clark
That's great to hear! If there are any details from your troubleshooting process that might help someone else facing a similar issue, please post them here if you want 🙂
Glad things worked out for you
Best,
Katie
