make arcgis online map searchable, and why can't I upload featured layers?
3738
08-06-2014 06:25 PM
willMcDonald
I'm not very good with the IT aspect of map creation, and I need some help with using arcgis online and why some things don't work.  First if I upload content to my content in arcgis online, then I go to create map, Add, search for layer, my content; there is nothing there, why isn't my layer there?  I am able to, while creating a new map, upload directly to the map and I can make a basic viewer app such as this one i created (http://www.arcgis.com/apps/Viewer/index.html?appid=e9cbd6f489a3446b804f04d11d4948d8) but if I try to make a searchable or filter app map it will not work.  also when I load up my mobile arcgis app it won't view the map, What's the deal?
I am guessing I need my files hosted on a server, except does it need to be some special gis service like arc2earth?  I used to use arc2earth when it was free to have editable maps on my phone for field research, i'm not sure how it worked, but it did.  I have access to a server, is it sufficient to just have my layers uploaded to a directory then use the layers url to get the content on my argis online map?
Thanks for any help
willMcDonald
bump
KellyGerrow
Esri Alum
Hi Will,
In order to interact with a feature layer in ArcGIS Online, you will need to publish a hosted feature service, if you have an subscription to ArcGIS Onlne. Once the feature service is published, you will be able to add the layer to web maps, in a similar fashion to how you would use a feature class in ArcMap.
Let me know if you have more questions,
Kelly
