Load Geotiff file into ArcGIS online
1476
05-16-2024 09:05 AM
JonathanHall3
Hi, I'm to find ways to import a spatial interpolated grid created using IDW method in MapInfo (saved under .MIF and .MIDI formats) into an ArcGIS online web map?  I gather I might have to rerun the grid calculations in QGIS and then save as a GEOTIFF file.  And then upload to ArcGIS Pro and create a tile service to save to ArcGIS online?
SteveCole
Honored Contributor
This will be an out of the box idea but, depending how the size of the raster, you could also consider using a Media Layer. This probably isn't the way ESRI was intending to use these layers but your could- export your grid as a JPG or PNG and follow the instructions for adding it to your map. It's one way of adding raster content that might make sense for pure visual purposes over a small area (Media Layers have to be less than 10mb in size)..
