Line chart in web map Pop-up
364
01-22-2026 03:23 PM
Hailey215
Is it possible to create a line chart in a web map pop-up that has multiple lines on it? I want to display soil temperature over time for the three different soil depths in my layer and include them all on the same chart as three separate lines. Any thoughts would be greatly appreciated!
IssyAmis
Hi @Hailey215
Thanks for your question.
I found the following documentation that might help you out with this workflow:
https://doc.arcgis.com/en/arcgis-online/create-maps/line-chart-mv.htm#:~:text=No%20aggregation-,Mult...
There is also the following Esri Community article that runs through a potential workflow that might work for you: Arcade Line Chart Pop-up with multiple series - Esri Community
If this isn't quite what you're looking for, please do let me know and I can run my own test on it to find a potential workflow. If you'd be open to attaching a sample of your data, or just a screenshot of what it looks like and what you are hoping to achieve - that would be great.
Thanks!
Issy
