Legend Displays in IE but not Chome or Firefox
4756
03-25-2015 08:25 AM
IanShepherd
I currently am using a pretty vanilla template that I use to host a map on our server. For some reason the legend will display on IE but does not work for Chrome/Firefox. Any idea why this would be?
Thanks
KellyHutchins
Esri Notable Contributor
It looks like that's an old version of the Basic Viewer template.  If you use one of the current templates available in the ArcGIS Online gallery do you seem the same issue with the legend not working in Chrome or Firefox?  You can test using this url. Just replace the existing web map id with yours.
http://www.arcgis.com/apps/MapTools/index.html?webmap=93791811ea1c432e91570546909fcc1b
KellyHutchins
Which template are you using? Is it one of the out-of-the-box templates or is it something custom you've created?
Is the app public? If so can you share the url?
IanShepherd
It is an out of the box template. It is not public but I can share the html code. Sorry the code isn't in the proper format. When I tried to include it earlier you couldn't see any of the code.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <title></title>
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.8/js/dojo/dijit/themes/claro/document.css">
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.8/js/dojo/dojox/layout/resources/FloatingPane.css">
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.8/js/esri/css/esri.css" />
    <link rel="stylesheet" type="text/css" href="css/layout.css">
    <!--[if IE]>
      <link rel="stylesheet" type="text/css" href="css/ie.css" />
    <![endif]-->
    <script type="text/javascript">
    var path_location = location.pathname.replace(/\/[^/]+$/, '');
    var dojoConfig = {
      parseOnLoad: true,
      packages: [{
    </script>
    <script type="text/javascript" src="//js.arcgis.com/3.8/">
    </script>
      dojo.require("esri.layout");
    </script>
    <script type="text/javascript" src="javascript/layout.js">
    </script>
      dojo.require("utilities.App");
      dojo.require("templateConfig.commonConfig");
      var i18n;
      dojo.ready(function(){
        i18n = dojo.i18n.getLocalization("esriTemplate","template");
        var  defaults = {
        //The ID for the map from ArcGIS.com
        webmap: "c43401a925db4ccda056a74a18e63e03",
        //Modify this to point to your sharing service URL if you are using the portal
        sharingurl: "http://www.arcgis.com",//for example: "http://www.arcgis.com",
        //The id for the web mapping application item that contains configuration info - in most
        ////When editing you need to specify a proxyurl (see below) if the service is on a different domain
        //Specify a proxy url if you will be editing, using the elevation profile or have secure services or web maps that are not shared with everyone.
        proxyurl: "",
        //cases this will be null.
        appid: "",
        //set to true to display the title
        displaytitle: true,
        //Enter a title, if no title is specified, the webmap's title is used.
        title: "Military Installations",
        //Enter a description for the application. This description will appear in the left pane
        //if no description is entered the webmap description will be used.
        description: "A map of U.S. Military Bases and how they align with Radio and TV Markets.",
        //specify an owner for the app - used by the print option. The default value will be the web map's owner
        owner: '',
        //Specify a color theme for the app. Valid options are gray,blue,purple,green and orange
        theme: 'blue',
        //Optional tools - set to false to hide the tool
        //set to false to hide the zoom slider on the map
        displayslider: false,
        displaymeasure: false,
        displaybasemaps: true,
        displayoverviewmap: false,
        displayeditor: false,
        displaylegend: true,
        displaysearch: true,
        displaylayerlist: true,
        displaybookmarks: true,
        displaydetails: false,
        displaytimeslider: true,
        displayprint: false,
        displayprintlegend: false,
        //i18n.viewer.main.scaleBarUnits,
        //The elevation tool uses the  measurement tool to draw the lines. So if this is set
        //to true then displaymeasure needs to be true too.
        displayelevation: false,
        //This option is used when the elevation chart is displayed to control what is displayed when users mouse over or touch the chart. When true, elevation gain/loss will be shown from the first location to the location under the cursor/finger.
        showelevationdifference: false,
        displayscalebar: false,
        displayshare: false,
        //Set to true to display the left panel on startup. The left panel can contain the legend, details and editor. Set to true to
        //hide left panel on initial startup. 2
        leftPanelVisibility: true,
        //If the webmap uses Bing Maps data, you will need to provide your Bing Maps Key
        bingmapskey: commonConfig.bingMapsKey,
        //Get the default map units
        units: commonConfig.units,
        //specify a group in ArcGIS.com that contains the basemaps to display in the basemap gallery
        //example: title:'ArcGIS Online Basemaps' , owner:esri
        basemapgroup: {
          title: null,
          owner: null
        //Enter the URL's to the geometry service, print task and geocode service.
        helperServices: commonConfig.helperServices,
        //Set the label in the nls file for your browsers language
        printlayouts: [{
          layout: 'Letter ANSI A Landscape',
          label: i18n.tools.print.layouts.label1,
          format: 'PDF'
          layout: 'Letter ANSI A Portrait',
          label: i18n.tools.print.layouts.label2,
          format: 'PDF'
          label: i18n.tools.print.layouts.label3,
          format: 'PNG32'
          label: i18n.tools.print.layouts.label4,
          format: 'PNG32'
        printlayout: false,
        printformat: "PNG32",
        //Specify the geocoder options. By default uses the geocoder widget with the default locators. If you specify a url value then that locator will be used.
        placefinder: {
          "url": "",
          "countryCode":"",
          "currentExtent":false,
          "placeholder": "",
          "singlelinefieldname":""
        //when true locations searches use the current map extent.
        searchextent: false,
        //Set link text and url parameters if you want to display clickable links in the upper right-corner
        //of the application.
        //ArcGIS.com. Enter link values for the link1 and link2 and text to add links. For example
        //url:'http://www.esri.com',text:'Esri'
        link1: {
          url: '',
          text: ''
        link2: {
          url: '',
          text: ''
        //specify the width of the panel that holds the editor, legend, details
        leftpanewidth: 228,
        //Restrict the map's extent to the initial extent of the web map. When true users
        //will not be able to pan/zoom outside the initial extent.
        constrainmapextent: false,
        //Provide an image and url for a logo that will be displayed as a clickable image
        //in the lower right corner of the map. If nothing is specified then the esri logo will appear.
        customlogo: {
          image: '',
          link: ''
        //embed = true means the margins will be collapsed to just include the map no title or links
        embed: true
        var app = new utilities.App(defaults);
        app.init().then(function(options){
            initMap(options);
    </script>
  </head>
  <body class="claro">
    <div id="bc" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false"
    style="width:100%; height:100%;padding:0;">
      <!-- Header Section-->
      <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
        <!--Title dyanmically generated -->
        <div id="nav" style='display:none;'>
          <!-- links are dynamically generated-->
          <ul>
            <li id="link1List"></li>
            <li>|</li>
            <li id="link2List"></li>
          </ul>
        </div>
      </div>
      <!--End Header-->
      <!-- Main Content Section (map, toolbars, left panel)-->
      <div id="mainWindow" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"
      style="width:100%;height:100%;">
        <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false"
        style="width:100%;height:100%;padding:0;">
          <!-- Toolbar (Search Basemap Measure)-->
          <div id="toolbarContainer_bv" data-dojo-type="dijit.layout.ContentPane" data-dojo-props='region:"top"'>
            <div data-dojo-type="dijit.Toolbar">
              <div id="webmap-toolbar-left">
                <!--Toolbar buttons (Legend, Details, Edit) created dynamically-->
              </div>
              <div id="webmap-toolbar-right">
                <!--create the search tool-->
              </div>
              <div id="webmap-toolbar-center">
                <!--Basemap,measure,share,time and layer list tools added if enabled-->
              </div>
            </div>
          </div>
          <!--End Toolbar-->
          <!--Left Panel-->
          <div data-dojo-type="dijit.layout.BorderContainer" id="leftPane" data-dojo-props="design:'headline', gutters:false,region:'left'"
          style="height:100%;padding:0;display:none;"></div>
          <!--End Left Panel-->
          <!-- Map Section -->
          <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props='region:"center"' dir="ltr">
            <div id="logo" class="logo" style="display:none;">
              <!--If a logo is specified in config section then the logo will be added
              to the map-->
            </div>
            <!--Floating window that contains the measure dijit-->
            <div id="floater">
              <div id="measureDiv"></div>
            </div>
            <!--Floating window contains the time slider-->
            <div id="timeFloater" style='display:none;'></div>
          </div>
          <!--end Map section-->
        </div>
      </div>
      <div id="bottomPane" dojotype="dijit.layout.ContentPane" region="bottom"
      gutters="false" style="display:none;margin:10px 5px;width:auto;height:275px;background-color:white;"></div>
      <!-- End Main Content section-->
    </div>
  </body>
</html>
KellyHutchins
IanShepherd
Kelly it works great. Thanks! Where can I download the newest version of the Basic Viewer template?
KellyHutchins
The template I linked you to is called Map Tools and can be downloaded here:
Esri/map-tools-template · GitHub
The Basic Viewer if you prefer to use that is available here:
Esri/basic-viewer-template · GitHub
