Layer name showing up twice in legend
929
03-23-2012 07:46 PM
JessicaSchoner
I made a web application for a map I created on ArcGIS online just using the default publishing settings from the basic template.  The layer name appears twice in the legend in the web app.  Is there any way to get rid of this?
View the issue here: http://www.arcgisonline.com/apps/OnePane/basicviewer/index.html?appid=3c3ff18474d94ca295ad76aeaef78e...
Thanks!
MikeMinami
Esri Notable Contributor
Thank you for reporting this issue. I can reproduce it and have documented the problem. At this time, there is no workaround. We should have a fix installed at the end of this week.
Mike
TanyaMeeth
This doubly layer name in legend still seems to be an issue.  Is there any update as to when this might be fixed?
thx.
MikeMinami
This should be fixed already.  Can you provide the URL to the map service you've added to your map?
Try clearing your browser cache (making sure to clear for the proper amount of time).
Mike
TanyaMeeth
Thx Mike - that works....
