Labels not show in new map viewer
2719
02-19-2023 10:05 PM
GisMan
When i open the map viewer classic and create labels with custom font, the label is showing correctly. But in new map viewer, the label didn't appears. I'm looking for the solutions in all sources, but i cannot see any of the correct solutions even from the Esri. Can anyone help please.
RussRoberts
Esri Notable Contributor
Can you share the web map?
RussRoberts
GisMan
Please see the following URL. We are facing this problems for a long time but we didn't see any solutions. Highly appreciate for your help. Thanks
https://arcg.is/1inH5S3
RussRoberts
thanks, looks like an issue in the 4.x API displaying these characters. Would recommend creating an issue with support for you to track. You can see in the dev console error showing the issue when trying to create labels on the field.
Laura
by MVP Regular Contributor
I am also having this problem, but in Portal
