Is there an AGOL equivalent to the Label Stacking options provided in ArcGIS Pro?
Or is there a way to achieve this using Arcade, since AGOL does accept Label Expressions.
Here's a script that splits lines at a set character length (maxLength)
var maxlength = 15;
var myArray = split($feature["YourFieldNameHere"], " ");
var string;
var lineArray = [];
var lineLength = 0;
for (var k in myArray) {
if (count(myArray[k]) <= maxlength) {
if (lineLength <= maxlength) {
Push(lineArray, trim(myArray[k]))
lineLength += count(trim(myArray[k]) + (count(lineArray) - 1))
if (lineLength > maxlength) {
string += Concatenate(lineArray, " ") + TextFormatting.NewLine;
lineArray = [];
lineLength = 0;
} else {
if (lineLength > 0) {
TextFormatting.NewLine +
trim(myArray[k]) +
lineLength = 0;
lineArray = []
} else {
string += trim(myArray[k]) + TextFormatting.NewLine;
if (lineLength > 0) string += Concatenate(lineArray, " ");
return string;
It's not completely obvious but it's there.
var words = Split($feature["YourFieldNameHere"], " ")
return Concatenate(words, TextFormatting.NewLine)Starter for ten, insert your field name and adjust to suit.
var maxlength = 15;
var string;
var lineArray = [];
var lineLength = 0;
lineArray = [];
lineLength = 0;
} else {
trim(myArray[k]) +
lineLength = 0;
lineArray = []
} else {
return string;
Thanks, @KenBuja! This is exactly what I was hoping for.
