Label Stacking?
1311
02-04-2025 02:02 PM
JoseLGonzalez
Is there an AGOL equivalent to the Label Stacking options provided in ArcGIS Pro?
Or is there a way to achieve this using Arcade, since AGOL does accept Label Expressions.
KenBuja
MVP Esteemed Contributor
Here's a script that splits lines at a set character length (maxLength)
var maxlength = 15;
var myArray = split($feature["YourFieldNameHere"], " ");
var string;
var lineArray = [];
var lineLength = 0;
for (var k in myArray) {
  if (count(myArray[k]) <= maxlength) {
    if (lineLength <= maxlength) {
      Push(lineArray, trim(myArray[k]))
      lineLength += count(trim(myArray[k]) + (count(lineArray) - 1))
      if (lineLength > maxlength) {
        string += Concatenate(lineArray, " ") + TextFormatting.NewLine;
        lineArray = [];
        lineLength = 0;
  } else {
    if (lineLength > 0) {
      TextFormatting.NewLine +
      trim(myArray[k]) +
      lineLength = 0;
      lineArray = []
    } else {
      string += trim(myArray[k]) + TextFormatting.NewLine;
if (lineLength > 0) string += Concatenate(lineArray, " ");
return string;
DavidPike
MVP Notable Contributor
It's not completely obvious but it's there.
var words = Split($feature["YourFieldNameHere"], " ")
return Concatenate(words, TextFormatting.NewLine)
Starter for ten, insert your field name and adjust to suit.
KenBuja
var maxlength = 15;
var string;
var lineArray = [];
var lineLength = 0;
        lineArray = [];
        lineLength = 0;
  } else {
      trim(myArray[k]) +
      lineLength = 0;
      lineArray = []
    } else {
return string;
JoseLGonzalez
Thanks, @KenBuja! This is exactly what I was hoping for.
