Juypter Notebook (via ArcPro) missing menu bar
13156
25
11-20-2021 02:55 AM
Abdulqadoos
So when ESRI's ArcPro was updated a week+ ago, the menu bar in juypter notebook disappeared. Now I have a hard time resetting kernels and doing basic functions (not stopping me but extremely annoying). Screenshot below.
Any ideas on how I turn it back on. I can see a flash of the menu with the Juypter logo when I first open a notebook, but then all I get across the top is "Edit, View, Inset, Cell, Help" and I know the View button isn't showing all the options it normally does.
Yes, the instance of Juypter notebook is installed as part of ArcGIS Pro - since it added it anyway, I've just been using that.
Thanks in advance. Link
Kelly
Juypter Notebook version 5.7.10 ArcPro 2.9.0
DanPatterson
MVP Esteemed Contributor
yes, something was done
I use JupyterLab outside of Pro, The file that needs to run is
C:\... YouInstallFolder ...\bin\Python\envs\arcgispro-py3\pythonw.exe "C:\... YouInstallFolder ...\bin\python\envs\arcgispro-py3\Scripts\jupyter-lab-script.py"
So basically you need to run jupyter-lab-scripy.py which is located in the scripts folder
I just created a shortcut on my desktop to make it easier to run
... sort of retired...
by Anonymous User
Not applicable
Thank you, Dan! Your work-around worked for me.
Carole
DanPatterson
No problem, it seem to work for some at least
Adam222
I get this when I try to open with Jupyter Lab.
EugenioArima
Exactly the same issue here.
DanPatterson
but as I said, when I ran Jupyter Lab outside of Pro, and then made a new Jupyter notebook inside of Pro, the menus returned.
Lab reset something in Notebook
Jupyter Lab ==> Jupyter Notebook == Menus
EugenioArima
I tried on both my arcgispro-py3 and my cloned environment and unfortunately the trick didn't work. Thanks anyways.
DanPatterson
C:\_Your_Install_folder_\bin\Python\envs\arcgispro-py3\pythonw.exe "C:\_Your_Install_folder_\bin\python\envs\arcgispro-py3\Scripts\jupyter-lab-script.py"
Is the shortcut executable, or try it from the command line
EugenioArima
Yep. Jupyter lab works fine but Jupyter notebook inside or outside Pro continues not showing the 'File' menu. Not a big deal but annoying.
