Join Feature Analysis Error - Unable to Add Feature Service Definition
733
06-14-2019 06:59 AM
JAVIERVARA_SANZ
Workflow below:
  1. Survey123 Connect: Publish Survey containing a repeat (table)
  2. Add resulting layer AGOL Map Viewer
  3. Run Join Feature to join feature service with related table (globalid to parentglobalid - ONE TO MANY). Also checked "Create results as hosted feature layer view"
  4. Obtain error: "Unable to add feature service definition"
Notes:
  • The hosted feature layer view is created but not accessible (error message provided)
  • I'll be using the join table to produce a Dashboard summarizing data
  • I was able to run the tool in the past without errors with a Survey generated the same way
