Join existing map to external CSV
707
09-07-2024 07:26 PM
FenHow
Hello, I am pretty sure this can be done but so far I have not found the right answer.
I have a map that has about 200 records in it. Each record was georeferenced and has a unique ID
The data behind the unique ID changes regularly in a CSV file. I was wanting to just update the existing records in the map with the new data for each unique ID.
Is there a way to join the unique ID for each record to an external CSV file?
Thank you.
Fen How
Laura
by MVP Regular Contributor
This is one way: https://community.esri.com/t5/arcgis-pro-questions/how-to-update-attribute-table-from-a-csv-and-add/...
Otherwise you should be able to update your data using the ID field through the append tool.
