Issue with arcade IIF for background color
822
09-14-2022 08:40 AM
AdejumoBidemi
Hi everyone,
 I'm trying to change background color based on value but the IIF is not working instead the whole list is giving the background color (both 1 & 2 value). Below is my code
var bgcolor = IIF(DomainName($datapoint,'FHE')==1,'#FF0000','');
return {
textColor: '',
backgroundColor: bgcolor,
separatorColor:'',
selectionColor: '',
selectionTextColor: '',
any suggestions
jcarlson
MVP Esteemed Contributor
A "domain name" is pretty much always a string, so comparing the domain name to an integer will always give you the result false. Are you meaning to compare the value of the code?
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
AdejumoBidemi
Yes... I tried using the text value which is Yes/No but I still get the same result
