Is there a way to upload a saved symbology file (.qml) from QGIS and upload this into AGOL? I cant see any options?!
1056
07-27-2021 08:49 AM
LottieLeigh-Browne
Tags (3)
George_Thompson
Esri Notable Contributor
I did not see .qml on the supported list: https://doc.arcgis.com/en/arcgis-online/reference/supported-items.htm
Is there another format that could be exported that may be supported?
--- George T.
LottieLeigh-Browne
I can also export the symbology from QGIS in .sld. Doesnt look like this is supported either?
jcarlson
MVP Esteemed Contributor
You can put it into a .zip archive and upload that, although you'll need to tell AGOL that the ZIP is a shapefile or GDB.
You may be better off opening the layer in an ArcGIS Desktop program and exporting a style file from there. If you just need to host the QML for others to access, consider using a more generalized file platform like dropbox, or even GitHub. AGOL is really meant for use with ESRI products.
- Josh Carlson
Kendall County GIS
RussRoberts
Currently this is not supported. Are you using points lines or polygons symbols?
