Is there a way to edit data using Microsoft Power Apps to update features in a feature class?
1074
01-13-2020 10:27 AM
RPGIS
Occasional Contributor III
I just have a simple question. Is it possible to update features from forms filled out in Microsoft Power Apps that are linked to the data through SQL Server? The reason being is that I was curious to see if this is something that is remotely possible, because I would like to use collector to add the related table from which the table is then filled out in a form. I don't know if I am shooting for the stars on this, but when I came across the ability in Power Apps to connect to data using SQL, I thought at least that it could be a possibility. If anyone has any ideas on this or experience with it, I would like to here it.
Robert
by Anonymous User
Not applicable
ArcGIS Maps for Power BIGeodatabase‌ spaces might have some ideas on this workflow.
RPGIS
Thanks Peter. I will give that a look and see if I can find anything. If not, I will try asking then.
