Is it possible to showcase story map into Public Map Gallery ?
814
01-03-2013 09:22 AM
YamMagar
I have been using Public Map Gallery version 1.3.1 to showcase all map applications build in ArcGIS Online. I am curious if one can showcase storytelling maps (customized) into the gallery. I am trying to use this template :http://storymaps.esri.com/stories/watersheds/ to showcase in the gallery.
Any idea?
Thanks.
MikeMinami
Esri Notable Contributor
A version of the public map gallery is now included as part of ArcGIS Online. For any group you have that is shared publicly, you can create a gallery from the group using one of two group templates. If the group contains web maps or web mapping applications, they will be displayed.
The watershed application you reference is not one of the out-of-the-box templates. However if you have an application running on your web server, you can add it as an item to your My Content, by adding an item of type "application" in the Add Item dialog. Then, share that item with everyone and also add it to your group. Then you can use the Share button on the Group page to create a gallery application, published to ArcGIS Online.
Hope this helps,
Mike
YamMagar
Thank you Mike ! It worked well as you advised.
