Is it possible to always have the legend visible in ArcGIS online instead of only having it visible when the mouse hovers over?
1472
12-12-2019 07:23 AM
JessicaHewitt
I am trying to figure out a way to keep the legend visible as soon as the map loads, instead of having it visible only when the user hovers over legend.  Please let me know if anyone can help with this situation.
Thanks!
RickeyFight
MVP Regular Contributor
Jessica Hewitt
Can you provide a screen shot of where the legend is you are talking about?
Is this on a webapp or in AGOL map?
JessicaHewitt
Here's the 2 screenshots.  It's through the story map app.  The legend (although it shows layer icon) is only available when the mouse hovers over top.  I was wondering if it's possible to always have it visible.
RickeyFight
Which version of story map? Are you going to be hosting this or will it be hosted on AGOL?
JessicaHewitt
Do you mean am I using a template?  I am using the most updated online version... no template.  I will be hosting.
RickeyFight
Jessica Hewitt
I see, the Story map builder. If you are hosting then it should be possible. I will have to look at the code and see where the legend is located.
