Introduction & help for importing feature class
1543
05-10-2022 07:54 AM
Louis-PhilippeTessier
Hello everyone,
My name is Louis-Philippe, I am a mobility project manager working for a Swiss consulting firm and currently working on a GIS project about bicycle parking locations, for which I need your help 🙂
I would like to publish on ArcGIS Online a hosted feature class that has a layer and a table (see images attached below).
The goal is to create a webmap visible in FieldMaps that will enable users to click on any point and be redirected to a Survey123 form. We will then link the feature layer and table in order to :
1. Populate the form with existing data;
2. Enable users to fill the form and send the new data in the related table.
I hope this is clear enough, let me know if you need more details.
Katie_Clark
MVP Regular Contributor
For linking to Survey123 from a feature in a web map, you'll need to use a custom URL scheme in the pop-up design.
Check out this blog, hopefully it will help you get started!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
