Include Style Labels in Popup
1498
05-05-2021 08:28 AM
ZachBodenner
MVP Regular Contributor
I have a feature class stored on site, published to a server and being consumed in an AGOL web map. The feature class is a City Guideplan, where each parcel is given a Guideplan designation. In the feature class attribute, these designations are abbreviated (think PSP for "Public/SemiPublic" or MDR for "Medium Density Residential"). In my mxd that I used to publish the service, I have set the symbology to Unique Values, with each of the abbreviations having a label that is the full name of the designation.
Now working with the popup in my web map, I'm wondering if I can include the full-spelled out designation. In the attached image for example, can I alter the display of the attribute "Guideplan" from saying LDR (The code in the domain) to say instead "Low Density Residential"?
Happy mapping,
- Zach
XanderBakker
Esri Esteemed Contributor
Hi @ZachBodenner ,
There is no need to use Arcade in this case. Just go into the configure pop-up option of the layer, there you will find the option "configure attributes" and in the window that appears you can change the alias of the field name:
