Images in pop-ups are not shown in all APIs
1343
08-04-2011 07:28 AM
by Anonymous User
Not applicable
Original User: thomas.ebert@ooe.gv.at
Original Date: 2011-08-04T08:28:15-0600
Pop-ups with images are a great tool in arcgis-online. However, GIF-images and ArcGIS-Server-REST-maps are not presented in all Viewers or iOS-App.
GIF-Image
- Works in ArcGIS.COM Viewer
- Does not work in ArcGIS Explorer Online (Silverlight)
- Works in the ArcGIS App for iOS
ArcGIS-Server-REST-Image
- Does not work in the ArcGIS App for iOS
Any ideas why?
MikeMinami
Esri Notable Contributor
GIF Images are not supported by Microsoft Silverlight, which ArcGIS Explorer Online is built with. I'd suggest using a different image format like png.
I'm not sure why you're not seeing the REST images in Explorer Online and the iOS. Here's a URL that I'm using that works. The format I'm using is PNG and I assume you're using the &f=image option...I can't tell from your attachment.
http://services.arcgisonline.com/ArcGIS/rest/services/Specialty/World_Navigation_Charts/MapServer/ex...
If your server is behind a firewall, that could be a problem. You might need a client access policy file for Explorer Online, but I'm not sure. http://help.arcgis.com/en/arcgisexplorer/help/index.html#//01560000004p000000.htm
Hope this helps,
Mike
by Anonymous User
Not applicable
Original User: doris123
Hi Mike,
thank you for your prompt reply and your info about using GIF-images.
Here is my map with an AGS-REST-image included in the pop-up which doesn't work in iOS App and Silverlight Explorer, but working well in Arcgis.com-Viewer.
http://www.arcgis.com/home/webmap/viewer.html?webmap=6add66c5e0f745a1ab556038bdd9770d
ColT
MikeMinami
Not sure why...we'll have a look.
Mike
by Anonymous User
Not applicable
Hello Mike,
it's seems to be a good way to sleep one night about it and then analyze the problem once again.
The solution is: to format the used attribute fields (min/max coordinates) without "1000 Separator" and "0 decimal places". And now also the iOS App and the Arcexplorer Online show the REST-Map. The Arcgiscom-Viewer seems to be more tolerant 😉
ColT
