I am an eager newbie with a mission. I would like to export a map view as a reasonably large (say 3000 by 2000 pixels) pdf or png. I saw how to do this in ArcGIS Desktop but not in ArcGIS Online. Can someone help? My apologies if I failed to find the
1115
08-25-2016 08:16 AM
NicholasZvegintzov
I hope that made sense.
I found PRINT and can print as pdf but (1) formatted on a 'page' instead of just the map and (2) v low resolution.
I used screen capture which works OK but I wonder if there is a direct method?
DanPatterson_Retired
was it the help you found this reference in ? ArcGIS Online Help | ArcGIS
NicholasZvegintzov
Oops, I meant to reply to Dan Patterson:
Yes.  I searched for e.g. EXPORT, SHARE, PDF, PRINT...
I found PRINT on the ArcGIS Online menu and I can print as pdf but (1) output is formatted on a 'page' instead of just the map and (2) v low resolution.
I see EXPORT in ArcGIS Desktop but nothing in ArcGIS Online.
NicholasZvegintzov
Yes.  I searched for e.g. EXPORT, SHARE, PSF, PRINT...
I found PRINT on the ArcGIS Online menu and I can print as pdf but (1) formatted on a 'page' instead of just the map and (2) v low resolution.
