I hope that made sense.
I found PRINT and can print as pdf but (1) formatted on a 'page' instead of just the map and (2) v low resolution.
I used screen capture which works OK but I wonder if there is a direct method?
was it the help you found this reference in ? ArcGIS Online Help | ArcGIS
Oops, I meant to reply to Dan Patterson:
Yes. I searched for e.g. EXPORT, SHARE, PDF, PRINT...
I found PRINT on the ArcGIS Online menu and I can print as pdf but (1) output is formatted on a 'page' instead of just the map and (2) v low resolution.
I see EXPORT in ArcGIS Desktop but nothing in ArcGIS Online.
Yes. I searched for e.g. EXPORT, SHARE, PSF, PRINT...
I found PRINT on the ArcGIS Online menu and I can print as pdf but (1) formatted on a 'page' instead of just the map and (2) v low resolution.
