hyperlink in attribute to send email
8228
22
03-03-2023 08:27 AM
temprobertcottreau131313
Is there a way for an attribute table to contain a hyperlink allowing the person opening a popup to click on that email address to send an email to that person?  This would be in a webapp.
Katie_Clark
MVP Regular Contributor
Ok, no problem. If you still need additional assistance, a screenshot might help so I can know what you're seeing on your end. 🙂
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
This is how it looks when I click in the webapp
This is how I set it up Online
am I using the wrong HTML code?  I've never used HTML before.
Katie_Clark
It looks like you set it up just as text, not as code.
To enter as HTML code, make sure you are in the "source" view. You'll know you're in that view when the "OK" option is greyed out. When you switch out of source view (viewing the code) you should see a preview of what it will actually display as.
Best,
Katie
I couldn't access the Source window in the New Map Viewer and had to do this in Classic.  Thanks for that.
And I was very excited to see that this allowed it to work in the New Map Viewer.  Sadly, it still only brings up the email options without showing the columns I selected for the popup in Online.
I will assume that what I'm trying to do isn't possible.
Thanks for all your help, Katherine.
Rob..
Katie_Clark
Heh, well now I'm determined to solve this because it should be possible! I've circled all the areas to click to get to that interface in the screenshots below...
After adding the HTML we've discussed above, the pop-up looks like this, with both the email link and the attributes showing.
If you *still* aren't able to complete that workflow....I'm not sure. Confirming, are you the owner of the map that you are trying to edit the pop-ups for? What user type are you in AGOL?
Best,
Katie
First of all, I don't get the Source option in the Text box in New Map Viewer, only the Undo and Redo arrows so I had to do this portion in Classic.
First I selected Configure Attributes and selected the columns to show
Then I clicked the green Configure button and entered the correct HTML code in the Source screen.
Still my popup looks like this.
I own the map.
User Type = Creator
Role = Publisher 1 (Group Sharing)
Katie_Clark
No idea why the source option isn't available for you in the New Map Viewer pop-up configuration, but in Classic, when you enter HTML in a custom pop-up configuration, you have to manually add any fields you want to display in addition to the HTML. You do this by putting the field name in curly brackets within the regular text view (not the source HTML view)
Best,
Katie
Katie_Clark
Also, I had just assumed you were doing this in ArcGIS Online, but are you using Enterprise instead?
Best,
Katie
