How to use the Traverse tool in ArcGIS PRO?
1000
12-05-2018 06:57 AM
KarenHoelscher
Is anyone else having problems working with the Traverse tool in ArcGis Pro? I've been unable to get it to work or find anything helpful so I have to go back to Desktop where I have no problem using the traverse too. My goal this year was to move over to Pro completely, but if I cannot figure out how to plot a metes and bound description I might as well stay in Desktop.  Any advice or links to a video would be greatly appreciated!
KarenHoelscher
FYI - When you hit the traverse tool under the Edit tab nothing happens other than your cursor changes to allow you to start your beginning place....nothing else happens. I finally started clicking on different tabs and finally found that once you start the tool IF you click on the MODIFY FEATURE tab is where you can enter the calls for the metes and bounds description.
Maybe ESRI can put that kind of information in the steps to use the tool OR have that window open up when you click the traverse tool. screenshot of traverse tool steps
