How to remove template for creating new features from field maps, but only for that map?
2302
09-27-2023 09:41 AM
Savannah2019
I have a layer that will be put in field maps for end users to edit. This feature layer is in my map 3 different times with different filters. Two are for editing the existing data points and one is for creating a new record. These will have different forms.
I only want the end users to be able to add a new feature for the one layer in the map with the form designed for new entries. But the other two layers, since they are all a part of the same feature layer and thus have the same settings, still show up in the template options when creating a new point.
Is there a way to remove a the unnecessary templates seen in the edit option in field maps when creating a new feature without removing the ability to edit those other filtered layers and without locking down the entire layer from creating a new record?
Miralem_Zeljo
I am sorry to see that noone replied to this for this long.
This is rather a big problem.
EmilyGeo
One possible solution would be to use hosted feature layer views and set different editing permissions on the views.
For example, View 1 could have editing enabled and allow users to add features.
Subsequent Views (2 and 3) could have editing enabled but not allow users to add features.
