Hi All,
I added a Living Atlas Layer as a basemap to my ArcGIS Online web map and when I try to remove it from the content the remove option is grayed out. How do I get rid of this as a basemap layer?
Thanks!
Hi Tanya,
You can't remove basemaps - you can only replace a basemap with another basemap. If you select another one it will replace the living atlas layer. Hope that helps!
Hi Tanya,
Thanks so much...that worked!
