How to Preserve Editor Tracking Info when uploading FL via Python
1020
08-02-2024 02:46 AM
JosephHilliard94
Hi there,
I have been adding a geodatabase to ArcGIS Online using the ArcGIS API for Python as my geodatabase is too large to publish via out of the box tools in Pro. Then I am publishing using that geodatabase item via the API. I need to be able to retain all the editor tracking info (which you can do out of the box in Pro) but I cannot work out what you have to specify in the publish parameters. I have seen other threads in the community such as this one - Solved: Publishing to AGOL overwrites editor tracking data - Esri Community but I cannot get this line of code to work (as it only seems to be available as in the response in the API documentation):
pub_params = {"editorTrackingInfo" : {"enableEditorTracking":'true', "preserveEditUsersAndTimestamps":'true'}}
Any help would be greatly appreciated!
Joe
JosephHilliard94
I worked this out myself, process below if it helps anyone:
Limitations of current methods for large feature services:
  • ArcGIS Pro – Publish will timeout.
  • Using ArcGIS API for Python Add & Publish – Cannot retain editor tracking information or symbology.
New Method
Step 1
  • Add feature classes/tables from geodatabase to ArcGIS Pro.
  • Apply symbology required for Feature Service.
  • Publish but Save as SD locally.
Step 2
Option 1:
  • Add SD using Add Item in ArcGIS Online.
  • Takes around 2 hours to upload so can timeout.
Option 2:
  • Add using ArcGIS API for Python:
item_props = {"type":"Service Definition",
                   "title":"Insert",
                   "tags":"Insert",
                   "description":"Insert",
                    "commentsEnabled" : False}
uploaded_sd = gis.content.add(item_properties=item_props,data=sd_path,folder="insert")
Step 3
  • Access the SD
  • Publish using the below parameters:
source_sd.publish(publish_parameters=pub_params, overwrite="true")
JosephHilliard94
New Method
Step 1
Step 2
Option 1:
Option 2:
                   "title":"Insert",
                   "tags":"Insert",
Step 3
  • Access the SD
