How to override Geocoding
1098
05-17-2021 06:05 AM
JRSchee
Hi there.  I am looking for a way to "disable" the search for addresses in ARCGIS Online Web Maps.
I work for an organization where we use property codes to search for our properties, however we are having an issue with the map searching and bringing up addresses first in our map we have imbedded in our companies program.
I have turned off the "by address" search function on the web map however it still searches an address first.  An example screen shot is below.  If you hit more results, it brings up our property code and the layer it is found on.  We would like for this to show first.
Is it possible to remove the geocoder as we do not need the map to search addresses.
Any help is greatly appreciated.  Thank you so much.
