how to find out which map viewer templates include a specific feature service
512
2 weeks ago
L77
My coworker is planning on deleting a feature service and I have it in several of my map viewer templates for use in offline areas.
I am concerned that if I don't remove the layer from my apps that it will break the syncing of my field maps.
How can I find out which map viewer templates contain the feature layer?
I have been manually opening every map to look for the layer and am concerned that I may have missed it in an app.
VenkataKondepati
1. Use ArcGIS Online Assistant or AGO Admin Tools
ArcGIS Online Assistant (Esri Labs) lets you log in and view the JSON of your maps and apps.
Open each web map’s JSON and search for the service URL of the feature layer in question.
Much faster than opening every map in Map Viewer.
Admin Tools for ArcGIS Online (by GeoJobe) has reports that let you list all items and their dependent layers. If your org allows add-ons, this is the most user-friendly way.
2. Search Your Content in ArcGIS Online
In your ArcGIS Online Content page, use the search bar with the feature service URL or part of the layer name.
This will often bring up maps and apps where the layer is referenced.
3. Programmatic Approach
If you’re comfortable with Python:
Use the ArcGIS API for Python to loop through your org’s web maps and search for the layer URL in their data.
Code snippet example:
from arcgis.gis import GIS
gis = GIS("home")
layer_url = "https://services.arcgis.com/xyzx/arcgis/rest/services/YourLayer/FeatureServer"
for item in gis.content.search("", item_type="Web Map", max_items=500):
    data = item.get_data()
    if data and "operationalLayers" in data:
        for lyr in data["operationalLayers"]:
            if layer_url in str(lyr):
                print(f"Layer found in map: {item.title} (ID: {item.id})")
This will list out all web maps containing the feature service.
4. Impact on Field Maps Syncing
Yes, if the service is deleted, sync will fail for any offline area or map that references it.
That’s why locating all references before deletion is critical.
Recommendation: If you don’t want to go the Python route, the quickest practical method is ArcGIS Online Assistant → search your JSON for the layer URL.
DanielFox1
Hi @L77
Certainly deleting the error will break the offline syncing, if anything like that happens you can follow this workflow to recover the offline data collection
How To: Access Offline Edits from ArcGIS Field Maps Directly from an iOS or Android Device
But I would recommend moving the data to you if you need it or complete all the work before it is deleted.
Laura
by MVP Regular Contributor
