how to change the default value obtained from the map in arc gis
1947
04-27-2016 01:29 AM
MansaPrakash
i have obtained a flow accumulation map from the aster dem image. the value obtained from the map is 0 to 2684501. now i need to change these value to 1 to 2684501 . so please tell me the procedure to change the default value
DanPatterson_Retired
in ArcGIS online??? For arcmap...  why not add 1 to the output, otherwise you have a whole messy reclass to deal with but extending the upper range by 1 shouldn't cause an issue.  otherwise use a Con statement and reclass 0 to some other value, keeping the others the same.
MansaPrakash
thank you sir
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avast.com
<#DDB4FAA8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
JayantaPoddar
Depending on what you want to do with the pixels of value 0, you could either replace them with NoData or 1 using Con tool or Reclassify, as suggested by Dan Patterson
Con—Help | ArcGIS for Desktop
Reclassify—Help | ArcGIS for Desktop
Think Location
