How do I correct the basemap data?
2907
6
08-05-2014 09:23 AM
DragonflyLight_Richards
I am finding some errors in my region in the World Topo, Topographic, and Streets basemaps. What is the easiest way to correct the basemaps?
Thanks for your suggestions.
Tags (1)
KenBuja
MVP Esteemed Contributor
Here are the way to submit feedback to the different maps
Topographic Map feedback
Imagery Map feedback
Street Map feedback
Those came from this thread, but problems with the forum migration removed the links.
KenBuja
Street Map feedback
Thank you! So if it is the same error propagated through all 3 maps, do I need to edit each one? I appreciate your quick response, Ken!
KenBuja
I don't have a good answer on that. Hopefully, if the error is on a common data layer for in all three maps, giving feedback on a single map would make it to all three. Then again, depending on how often each of them are updated, it might work to your benefit to note the change in each one.
MikeMinami
Esri Notable Contributor
You can just report the issue once. Several basemaps utilize the same underlying source data, so it will be fixed across basemaps.
Thanks
Mike
KenBuja
Hi Mike
Is the feedback for each of the basemaps read at the same frequency? Or is there a particular basemap that will get its feedback reviewed more often?
MikeMinami
The items posted to the feedback maps are periodically reviewed by a group of people. No basemap feedback is reviewed more frequently than others. Here's our general process:
Esri reviews the feedback to determine the source of the data issue and how best to address the problem.  If the source is from one of our commercial vendors, we report the issues back to them. All feedback is vetted by Esri and/or the data vendor to ensure correctness. Thus, not all feedback will result in a change in the data. If a change is required, it may take one or more delivery cycles from the data vendor for the change to be incorporated. Once Esri receives updated data, we periodically update our basemaps with the new data.
We encourage you to be as complete as possible in your feedback and to include your contact information so that we may contact you with any questions.  Vague or incomplete feedback is difficult to summarize into a correction note and may not get submitted for a fix.
thanks,
Mike
