How do I change whether a field is editable in a hosted feature layer?
873
07-21-2020 02:46 PM
JoshWhite
Honored Contributor
I recently moved from SDE to Hosted Feature Layers in ArcGIS Online.  I have a field in one of my layers that is not editable.  I'm not sure how this happened.  It is nullable but I can't delete the content because on ArcGIS Online it says the field is not editable.  Any idea how to change this?  I would just reload the SDE layer but I have done a ton of edits and didn't realize this was an issue until now.
Josh White, AICP
Principal Planner
City of Arkansas City
CraigRussell
Hi Josh
You should be able to modify this field setting by updating the layer definition from the REST Administrator Directory.  There are some instructions/examples for updating definitions here - Update Definition (Feature Layer)—ArcGIS REST API | ArcGIS for Developers
You can get to the administrator directory by navigating to the service URL and change it as follows:
FROM
TO
https://services.myserver.com/OrgID/ArcGIS/rest/admin/services/example/FeatureServer/0
Update Definition appears at the bottom of the page under supported operations:
When using this, only include the content that you want to change - i.e. to update the editable setting on a field, copy out and update only the JSON for that field.  E.g.
If you haven't worked with definitions like this before then I'd suggest that you try this against a test/copy of the feature layer first until you're comfortable with the process.
Hope this helps!
Craig
