How come shape__Length attribute appears 'Null' in AGOL
2713
09-27-2017 11:58 AM
DanielArsenault
Anybody had this issue that shape_length field shows 'null' for a feature hosted layer in AGOL and also when viewed from ArcGIS Pro.  But when i edit through ArcGIS Pro, the attributes windows, i can see all the values for length. Anybody encoutered this before?
AdrianWelsh
MVP Honored Contributor
Daniel,
Try running a Repair Geometry tool on your shapes. Also, it is easiest to post your screenshots as copied and pasted images versus adding a Word Doc like this:
https://community.esri.com/community/gis/web-gis/arcgisonline?sr=search&searchId=56fbc485-8cb1-4631-...
DanielArsenault
Can you run repair geometry function on a feature layer that is hosted on AGOL?
AdrianWelsh
Run the repair geometry tool on the layer in desktop first. Then republish it to AGOL (if it repaired the geometry).
