how can I make label using arcade that has multiple values
1787
08-21-2019 02:48 PM
ScottShenberger
I am trying to create an arcade expression that will pull only part of an attribute field. We track multiple document numbers in a field called DocumentNumber. Each document is separated by an !. I want to create a label from just the first document number. For example, I can have a document number field that looks like PN 123-4567!FN 1234 or FN 4567!PN 7654-123 (although document numbers vary by length depending on type) I would like to create a label based on the first value of the document number field which is where I am struggling
Thank you
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi Scott Shenberger ,
Could you try this:
return Split($feature.DocumentNumber, '!')[0];
ScottShenberger
That looks like it did the trick! Thank you so much. Im learning Arcade on the fly so this was stumping me.
BenBaker1
I'm trying to create a similar expression, although I need the expression to then sum the values from inspection types that are coded into a survey123 form. The question is a select_multiple type, because they may complete more than one inspection type during a single survey, but then I'd like to be able to summarize the number of EACH inspection in a Dashboard (now that Arcade is supported in indicators).
I have a formula in Excel that will parse the field and sum the individual values, but I would like to keep things on the ESRI platform, if possible.
Excel formula to find all '100' (Annual) inspection types:
I'm not sure how to make the jump from Split to summing the values, or if another function (GroupBy?) might better achieve what I'm wanting.
XanderBakker
Hi bbaker_mhgis ,
Although the new ArcGIS Dashboard (beta) has support for Arcade in the indicators, I am not sure if you can do a count of all values that contain a certain string.
