Hosted Map Service Fails to Refresh
4270
14
09-12-2017 07:08 AM
by Anonymous User
Not applicable
I have a hosted 10.5.1 map service, here: MapServices/fsmPublicMapViewer (MapServer)
Changes to this map service (e.g. add layer, change default visibility, etc.) are not reflected when I re-open the map in MapViewer. I have checked and set the refresh rate for the layer in AGOL to 1 minute and no luck.
Thanks in advance,
rGibson
KellyGerrow
Esri Alum
Hi Russell,
If you add the map service URL to the web map and don't change anything, like symbology, then the web map will pull the data (layers) and symbology right from the Map Service: MapServices/fsmPublicMapViewer (MapServer)  The web map will be able to see new layers or symbology set to the map service as no settings per layer will be stored in the web map. If any layer specific content is saved to the web map, a schema of the map service will be saved in the web map, and manging symbology and layers through the map service won't be possible.
Let me know if you have questions,
-Kelly
Lake_Worth_BeachAdmin
Are you saving the changes within Web Map viewer?
by Anonymous User
Not applicable
Hi Joe. All changes occur in the local mxd and then republished to the locally hosting service.
Russell Gibson,
Director, Information & Technology Services,
City of Fort Smith, AR
can you provide a screenshot of your configs for hosting the service?
by Anonymous User
Not applicable
Specifically?
The updates are reflected at the REST endpoint, etc.
Thanks again.
r
Russell Gibson
479-788-8919
[email protected]
KellyGerrow
Esri Alum
Can you share your webmap?
Was the service added as the full map service or as layers within the map service?
-Kelly
by Anonymous User
Not applicable
Full map service.
https://gisapps.fortsmithar.gov/arcgis/rest/services/MapServices/fsmPublicMapViewer/MapServer
Russell Gibson,
by Anonymous User
Not applicable
Should I open a support case for this issue, Kelly?
Thanks
rGibson
KellyGerrow
Esri Alum
Yes, or share the web map that you are using. Web Maps create a specific schema when accessing layers. If the underlying data is updated, sometimes the web map is unaware of the changes and doesn't submit calls to the new layers or features. In order to verify if this is the issue, i suggest looking at the specific web map.
If you add the map service to a new web map, does the new data appear?
-Kelly
by Anonymous User
Not applicable
http://fsm-ar.maps.arcgis.com/home/item.html?id=4a39661e35c343c9b0977351c5e2044e
Yes, if I add the service to a new web map, the updates appear. Also, if I preview the rest endpoint in the Javascript viewer, the update appears as well.
