Did you publish from ArcGIS desktop or ArcGIS.com?Sometimes there are problems publishing.
Are you seeing any error messages?
Do you have a full subscription with enough credits?
If publishing from desktop, what version do you have?
What web browser and version do you have?
I'd suggest trying again. If you still experience issues, perhaps you can share your data with us so that we may try to reproduce the problem.
Mike
there are days where I would have to wait a couple of minutes before the feature service is accessible.
So what does this mean to web maps that reference that layer? If you modified layer drawing or set a popup definition and simply saved your web map, those properties are stored in the web map and will be retained because the URL to the feature layer is still valid after overwriting and the drawing and popup definition are in the map.
