Hosted Feature Layers
1414
05-31-2022 01:51 PM
SLouq
by MVP Alum
I have an existing Hosted Feature Layer in our ArcGIS Online account which I created to work with a GNSS unit to get elevation readings. What I would like to do is use this functionality but in a different HFL. Is there a way where you can make a copy of the existing HFL and have it be it own feature separate from the existing layer?
I want to keep the existing HFL as a template for creating other HFL with that functionality.
Thanks
ChristopherCounsell
MVP Frequent Contributor
Not directly - need to export to feature collection or file geodatabase, and then create.
https://support.esri.com/en/technical-article/000024339
See note in below:
https://doc.arcgis.com/en/arcgis-online/reference/copy-save-layers.htm#ESRI_SECTION1_39F2936FFAEF498...
Could also look at using ArcGIS Pro and publishing from file geodatabase.
ChristopherCounsell
See note in below:
SLouq
by MVP Alum
Thank you for the link!
