Hosted Feature Layer View
6040
12
02-25-2019 08:05 AM
MichaelRichey
I created a "hosted feature layer view" so features can be added to this layer. Made the necessary adjustments in "Settings".
However, when I select "Edit" on this layer view, I get a message indicating "Feature creation is disabled for all layers".
What did I miss ?
Thanks, Mike-
KhaledHassen
Please check the view "IsUpdatableView". Normally the default is false which would prevent you from editing.
You can go the feature service update definition admin API and pass:
https://.../myOrg/arcgis/rest/admin/services/myServiceName/FeatureServer
{"isUpdatableView" : true}
Khaled Hassen
Online Feature Service Lead
MichaelRichey
Hi Khaled:
Appreciate your reply to my question.
I understood the part about the default is probably set to false and setting {"isUpdatableView" : true}
Where is that set ?
Everything else after that I did not understand. According to what I have read online, there should be a much more straightforward approach. If I’m wrong , let me know.
Thanks, Mike-
KhaledHassen
Sorry if I was not clear.
In order to set the view to be updatable you will need to use the feature service admin API.
This is where you can change the default. You can also specify this property when creating a new view service.
As I have mentioned above, pl. use the rest/admin API as specified in the example above and then pass the json I have specified above.
The admin API of the feature service follows the following url pattern. Pl. replace the url below with your view service url.
Khaled Hassen
MichaelRichey
I’ll have to get with our GIS Manager on this.
ChrisWhitmore
Hi Mike,
Would it be possible to post a screenshot of your feature layer view settings (where you configured editing)? It might just be a setting that needs to be updated.
Chris
MichaelRichey
Hi Chris:
This is for my hosted feature layer view.
Mike-
ChrisWhitmore
Awesome thanks..everything seems to be ok for the settings. Would it possible to share the layer privately so I can check it out? If so, you can invite my account to a private group the layer is shared with: cwwhitmore
Cheers,
Chris
MichaelRichey
OK, made a group “ESRI Redlands” and added you to it based on: cwwwhitmore
Received a tip that "IsUpdatableView" is set to false in feature layer service.
Have no idea how to check/change that.
Mike-
KhaledHassen
Mike,
As I have explained isUpdatableView false means you will not be able to edit unless you use the feature service admin API to turn it ON.
Pl. check the solution I have above. Not really sure if we have a UX to turn it ON.
Solution is very simple. Go the admin endpoint of the feature service view and execute updateDefinition and pass
This is all what you really need to do. We can do it for you if we have admin access to your service.
Khaled Hassen
