HELP: Why does the shapefile resolution change in ArcGIs ONLINE?
1350
05-25-2023 08:36 AM
dargandona
Please I need help because I am investing too much time in this problem.
When I work in ARCGIS-PRO (desktop) the shapefile visualizes correctly in the map. But when I upload the same shapefile as a compressed ZIP file to ArcGIS Online and then visualizes it in Map Viever the image resolution greatly reduces. Even when I generate the ZIP file with 0% compression factor (only storage), the problem remains.
Can you please give me a hint as to how to solve this problem?
What can I do to maintain the same resolution as in ARCGIS PRO?
Thank you very much in advance.
Daniel
ClayDonaldsonSWCA
I would suggest you publish directly from pro, rather than uploading a shapefile. It looks like it is generalizing for some reason.
Share a web feature layer—ArcGIS Pro | Documentation
BrianneMecum
Were you ever able to solve this issue? I'm currently experiencing the same issue and trying to troubleshoot to with no luck thus far...
