Help! Arcade expression to sum all values per globalid in related table
1143
04-05-2023 11:37 PM
Labels (2)
andrewtillinghast
Hi, I have a hosted feature layer "CCG_Idea_Submission" on AGOL. The layer has a related child table called "CCG_IS_Reactions." They both have records added by Survey123 apps -- "CCG_IS_Reactions" has a field called Support that is populated with a "1" integer every time someone submits a simple survey in another app.
What I'd like to do is to calculate a field [Support] in the parent table with an Arcade expression that sums up the field per parent feature. I'd like this to occur whenever a new record is added to the child table, not just a one-time static calculation.
Can anyone suggest an expression to do so? Thank you!
andrewtillinghast
Starting to think that what I'm looking for might not be possible using an Arcade expression as a field calculation - because as I understand it this would be a one-time calculation rather than one that would run constantly/whenever new inputs are added.
I didn't give the final intent in my original post - which is to feed this data into an ExperienceBuilder app. Maybe I could accomplish what I'm trying to do as a pop-up expression in a related map and then have the widget pull from the pop-up...
