GetUser() Arcade not working
1078
11-29-2023 12:07 PM
AlcoGISUser
Trying to calculate field in Smart Form/Field Maps with Arcade calculated expression to populate a field with the current user if another field has been populated.
var inspected = $feature.INSPECTION_STATUS;
var userInfo = GetUser();
IIF(IsEmpty(inspected) == 'False', userInfo.username, '');
Thought this should do it but entering a value into 'inspected' returns nothing.
Tags (1)
KenBuja
MVP Esteemed Contributor
IsEmpty returns a boolean, but you're comparing it to the string "False". This will always return False. Use this instead
IIF(!IsEmpty(inspected), userInfo.username, '');
