GET RID OF LEGEND?
786
05-01-2013 01:26 PM
JuneAcosta
Occasional Contributor III
I downloaded the simple viewer, but I need to get rid of the legend. I modified the the desktop.css by setting display: none for the selector, but when I set the display: none on the #leftpane the about button as well as the legend goes away.
My questions are: how do I get rid of the legend? Should I be controlling it in the .css? How do I get rid of the legend in the ipad.css, but still keep the about button?
Thanks in advance!
by Anonymous User
Not applicable
Hi June,
In the FixedSplitterfragment1.html file comment out the code below:
<li id="listItemLegend" data-dojo-type="dojox.mobile.TabBarButton" moveTo="legendSubView" selected="true"></li>
  <div id="legendSubView" data-dojo-type="dojox.mobile.ScrollableView" selected="true">     <div id="legendContainer">       <div id="legendHeader"></div>       <div id="legendDiv"></div>     </div>   </div>
And in the layout.js file you will want to comment out:
if (layerInfo.length > 0) {     var legendDijit = new esri.dijit.Legend({       map       :map,       layerInfos:layerInfo     }, 'legendDiv');     legendDijit.startup();   } else {     dojo.byId('legendDiv').innerHTML = i18n.viewer.sidePanel.message;   }
And for removing the button on a smartphone you would comment out:
// 'Legend' button     var legendToolBarButton = new dojox.mobile.ToolBarButton({       id     :'legendToolbarButton',       toggle :true,       icon   :'images/legendIcon.png',       style  :{         float        :'right',         width        :'44px',         'padding-top':'2px'       },       onClick:function () {         legendButtonSelectionHandler();       }     });     // for smartphones only, add the legend toolbar button to the right side of the header     if (isSmartPhone)       dijit.byId('rightPanelHeader').addChild(legendToolBarButton);
// build the div the will house the legend widget     if (isSmartPhone) {       var legendBackground = dojo.create('div', null, dojo.byId('rightPane'));       dojo.attr(legendBackground, 'id', 'legendBackgroundDiv');       dojo.setStyle(legendBackground, 'bottom', '2px');       dojo.setStyle(legendBackground, 'height', '180px');       dojo.setStyle(legendBackground, 'right', '5px');       dojo.setStyle(legendBackground, 'left', '5px');       dojo.setStyle(legendBackground, 'background-color', '#FFF');       dojo.setStyle(legendBackground, 'position', 'absolute');       dojo.setStyle(legendBackground, 'z-index', '10');       dojo.setStyle(legendBackground, 'opacity', '.8');       dojo.setStyle(legendBackground, 'overflow', 'scroll');       dojo.setStyle(legendBackground, '-webkit-border-radius', '6px');       dojo.setStyle(legendBackground, '-moz-border-radius', '6px');       dojo.setStyle(legendBackground, 'border-radius', '6px');       dojo.place('legendDiv', 'legendBackgroundDiv', 'first');       dojo.setStyle('legendDiv', 'margin', '1px');       dojo.setStyle('legendDiv', 'padding', '1px');       dojo.setStyle('legendDiv', 'font-size', '0.7em');       dojo.setStyle(legendBackground, 'display', 'none');     }
It's also worth checking out the sample here since it has an about button and no legend.  You would need to add the logic/design to view it on a desktop.
by Anonymous User
Not applicable
Hi June,
JuneAcosta
Thanks Chris!
