Get a list of domain values from feature layer?
5978
10-23-2020 01:07 PM
JaneSkillman
I'm new to arcgis API for python. I can't figure out how to get a list of domain values from a hosted feature layer. I did read the api-reference, and can see that there is a query_domain method for the FeatureLayerCollection class (here: arcgis.features module — arcgis 1.8.2 documentation ) but I don't understand the syntax well enough to figure out how to actually write the code.
Thank you,
Jes
Kevin_McIntyre
The best I could come up with is that you'll have to access the properties of the FL and loop through it to find coded values.
Here's a sample:
from arcgis import GIS
gis = ("https://arcgis.com", "username", "password")
#Get the arcgis item (this would be your hosted FGDB).
item = gis.content.get("itemID")
#Get the layers list from the item.
layers = item.layers
#Select the layer from the list you want to use.
fl = layers[0]
#Get the properties.
properties = fl.properties
#Loop through the JSON to extract the coded values and save them to a list.
lst = []
for row in properties[fields]:
   if row['domain']:
      lst.append(row['domain'])
That should get you a list of the dictionaries associated with each coded domain into a neat list.
Kevin_McIntyre
Here's a sample:
fl = layers[0]
lst = []
   if row['domain']:
JaneSkillman
Thank you Kevin!
Your post was very helpful and set me on the right path. This is what I ended up doing, in case this is useful to others.
def getDomainNames(itemID, layerNumber):
    Returns a set of domain names from a feature layer within a feature layer collection.
    :param itemID: identification number for an ArcOnline or Portal item (Feature Layer
     Collection or FGDB)
    :type itemID: str
    :param layerNumber: the integer [0 and up] that calls the feature layer of interest
    :type layerNumber: int
    # Assumes user is connected to their ArcOnline account in ArcPro.
    gis = GIS("pro")
    # Get the arcgis item (this would be your hosted FGDB).
    item = gis.content.get(itemID)
    # Select the layer within the feature layer collection.
    fl = item.layers[0]
    # Get the properties.
    # create an empty set
    nameSet = set()
    # Loop through properties, get a list of all coded values for the given domain.
    for row in properties["fields"]:
        # if domain exists for the field and the domain type is codedValue:
        if row['domain'] and row['domain']['type'] == 'codedValue':
            # add the domain name to the set.
            nameSet.add(row['domain']['name'])
    return (nameSet)
def getDomainValues(itemID, layerNumber, domName):
    Returns a list of domain codes from a specific domain within a feature layer.
     Collection or FGDB)
    :type itemID: str
    :param domName: name of the domain of interest
    # Assumes connected to duinc in ArcPro
    gis = GIS("pro")
    fl = item.layers[layerNumber]
    # Loop through properties, get a list of all coded value domains.
        # if domain exists and the domain name is correct:
        if row['domain'] and row['domain']['name'] == domName:
            # create a list of all codes included in that domain
            valueList = [i['code'] for i in row['domain']['codedValues']]
    return (valueList)
Kevin_McIntyre
Edit: After tinkering with the query domains method for Feature Layer Collections, I found out that it wasn't working at all and submitted the issue to ESRI. I think it's an issue with the REST API.
