GeoForm Add New Fields
1978
01-13-2022 10:18 AM
KATIEATKINSON
I am trying to update a GeoForm I created. I added a few new fields to the base feature service however they are not showing up in the form editor. I remember needing to add the fields in the JSON for the application however I cant remember how to get to that. Can anyone help me.
Tags (1)
RickeyFight
@KATIEATKINSON
Where is this geoform hosted? on AGOL or your own server?
KATIEATKINSON
AGOL
KATIEATKINSON
https://yubacounty.maps.arcgis.com/apps/GeoForm/index.html?appid=fa268a2b988847b7bf242201aa28ccd4
we are required to have an inventory of all the curbs and ramps in the county and if they meet requirements. SO I made an application that any of the road crew could use a phone to enter the measurements or new points as needed. The web map also will let them edit the points already placed.
RickeyFight
@KATIEATKINSON
This looks good. I am curious why you are not using collector and survey123?
https://github.com/Esri/geoform-template-js
KATIEATKINSON
At the time I could not get the domain dropdowns to work and I needed it to be able to add photos. After fighting with it for a day I found this and it worked much easier. BUt editing it has been more tricky
