Geodatabase Access Tool Arc Online
1520
02-18-2019 01:56 AM
JamesNolan
Is it possible to add a point data file (not published) from a database into a web map application (with select and filter capabilities) using the Geodatabase Access Tool in Arc Online.
AdrianWelsh
MVP Honored Contributor
James,
Can you define more about this geodatabase access tool?
Here is a brief summary of what you can put in ArcGIS Online
Add items—ArcGIS Online Help | ArcGIS
What can you add to ArcGIS Online?—ArcGIS Online Help | ArcGIS
JamesNolan
Hi Adrian,
The Geodatabase Access tool is listed in ARC ONLINE
See below
AdrianWelsh
Interesting, I find it odd that there is no documentation on this type of tool. Do you have a geodatabase access tool? When you click on it, it will list the tools:
I am guessing you (or the admin) will have to create a geodatabase access tool
Use the analysis tools—ArcGIS Online Help | ArcGIS
