ArcGIS Online: Web Map autohides field in Feature Class on second opening of Attribute Table
643
02-19-2019 09:45 AM
AdamGottner
I have never experienced this oddity before and I can't find any information on others who have experienced this.
We utilize Collector, AGOL Web Map and AGOL Web Application for a particular service we've created for a client.
Collector and the Web Application do not have a problem with the below description of the problem I am seeing. When I first open the Web Map and open the attribute table of a particular feature class I am able to see all fields as I should. The moment I close the attribute table and open it for the second time one field dissapears. The field name is 'WO' and field alias is 'Work Order #'. I can bring it back in a couple of ways. First is reconfiguring the pop-up so that the field shows in a different part of the line-up and clicking the + button in the attribute table and showing the field again. The moment I close and re-open the attribute table it auto-hides again.
I've never ran into this issue and can't find a setting that is telling this column to hide.
Any thoughts?
Adam
Laura_B
Hi Adam Gottner‌. What field type is the 'WO' field?
AdamGottner
This is a Text Field with the default character length of 50.
