Hi, can someone tell me how to change the size and color of the “flashing dot” that appears when you make a selection from a selector in a Dashboard?
I have looked and found where I can modify the flash rate by editing the JSON file, but not the size and color.
Thank you so much,
Fen
The color is in the dashboard theme settings:
The size, I don't think you can control without doing something really hacky, like buffering the point feature in a Data Expression or something.
Thank you. In the past on other maps the flash was a round dot, now its a rectangle and small and is drivng me nuts. I found the color change, that worked.
Thanks.
Fen
Weird, mine is still a dot. Are the features points, or polygons?
UPDATE: Found another way to do this just by changing the "Accent color" in the Custom theme settings (because that also seems to dictate the color of the flashing halo around the point when it's selected) and by poking around in the ArcGIS Online Assistant and making some edits in the JSON.
