Flashing Dot When Item Selected - Dashboard
1120
09-05-2024 10:32 AM
FenHow
Hi, can someone tell me how to change the size and color of the “flashing dot” that appears when you make a selection from a selector in a Dashboard?
I have looked and found where I can modify the flash rate by editing the JSON file, but not the size and color.
Thank you so much,
Fen
jcarlson
MVP Alum
The color is in the dashboard theme settings:
The size, I don't think you can control without doing something really hacky, like buffering the point feature in a Data Expression or something.
- Josh Carlson
Kendall County GIS
FenHow
Thank you. In the past on other maps the flash was a round dot, now its a rectangle and small and is drivng me  nuts. I found the color change, that worked.
Thanks.
Fen
jcarlson
MVP Alum
Weird, mine is still a dot. Are the features points, or polygons?
- Josh Carlson
Kendall County GIS
FenHow
Points.
