Filter Entire Dashboard or Experience By Logged In User
968
10-12-2023 10:28 AM
JoeAbercrombie
New Contributor II
Hi there,
I have moved to Agol from other services and I am having trouble with filtering. I have large datasets/maps that my technicians interact with, each feature is associated with a specific client. I serve interactive dashboards to these customers and they only see what features are filtered by their username/data. In other applications, this is a standard feature often called Row Level Security. I'm struggling with this on Agol, can I please get some advice on how to implement this; the mechanism, and most efficient approach ie. layer level, map level, dashboard, or experience?
Many thanks.
jcarlson
MVP Esteemed Contributor
You can use a Data Expression in your dashboard, as that gives you access to user variables through the GetUser() function. You can use that to get the logged-in user's name, then apply different filters, etc., based on that value.
- Josh Carlson
Kendall County GIS
JoeAbercrombie
New Contributor II
Hi there,
Would really appreciate some elabouration or ideally screenshots of exactly where and how you add the getuser function. Thanks
ArmstKP
@JoeAbercrombie @jcarlson I haven't been able to implement this yet, either.  I have a hosted feature layer, where one of the fields is the user that feature is assigned to.  I want to be able to obtain the logged-in user with arcade and then filter the map/features to only the features they are assigned to.....
DataOfficer
You can try something like this as your Data Expression
var fullname = GetUser()['fullName'] // alternatively change to ['username']
Console (fullname) // to check in the Console that the fullname is returned
var fs = FeatureSetByPortalItem( // get your feature service
    Portal('https://www.arcgis.com'),
    'itemid', //add in your itemid (e.g. '3385b003af5248e59c1fa68e1411c446')
    2, // change to relevant layer id (e.g. 0)
    false
Console(Count(fs)) // to get number of features in feature service in Console
var filfs = Filter(fs, `AssignedUser= '${fullname}'`) // change field as needed
Console(Count(filfs)) // check in Console that it is returning the correct number of features assigned to the user
return filfs
